Shell/Hollow with Selection error
shai_perednikshai_perednik Member Posts: 56 ✭✭
edited September 2016 in Community Support
I'm trying to hollow out this yellow part and struggling to understand why this hollowing is failing.  Onshape doc @ https://cad.onshape.com/documents/14f3d01d62b5237f728896c5/w/94d619557ed944a898f21d55/e/3965d76b2a483d281d37d261.
I could hallow it out just fine before I added the extrude in the front section
  • lougallolougallo Member, Moderator, Onshape Employees, Developers Posts: 2,001
    @shai_perednik It seems you have worked through this.  Let me know if this issue still persists.
  • shai_perednikshai_perednik Member Posts: 56 ✭✭
    Yep.  Actually had to redo the part today anyhow so fixed this issue then
