Create sketch in middle of part
Lee_Hesketh
Member, Developers Posts: 148 ✭✭✭
Hi all. I have a script where the user selects a face, then using qConvexConnectedFaces twice to select the ends. I have then found the midpoint of each of those faces and used them to find the midpoint of the part. What I need to do is create a plane at that point parallel to the end faces and then create a sketch. How could I do this?
Also, how could I implement the midplane feature from the plane command?
Thanks
Lee Hesketh
Thanks
Lee Hesketh
There are 10 types of people in the world. Those who know binary, those who don't and those who didn't expect base 3!
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
Hi Lee_Hesketh,
To create a plane, you can use the constructor that takes:plane (origin is Vector, normal is Vector) returns Plane
The origin of your plane is going to be the mid-point that you calculated and the vector should be the normal of the plane to make them parallel. Such that:var planeDef = plane(midPoint, plane1.normal);
From here, I would make an opPlane off of this:<div>opPlane(context, id + "plane", { "plane" : planeDef, "width" : 6 * inch, "height" : 6 * inch });</div><div></div>Then you want to make a sketch based on this planevar mySketch = newSketch(context, id + "sketch1", {<br><span style="font-family: Flama, sans-serif;"> "sketchPlane" : qCreatedBy(id + "plane", EntityType.FACE)<br></span><span style="font-family: Flama, sans-serif;">});</span>
Since you already have the mid-points, I would use the cPlane command with the cplaneType set to CPlaneType.MID_PLANE.cPlane(context, id, { <br> "entities" : [query of both mid-points], <br> "cplaneType" : CPlaneType.MID_PLANE, <br> "flipAlignment" : false, <br> "width" : 6.0 * inch, <br> "height" : 6.0 * inch <br>});Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
To create a plane, you can use the constructor that takes:The origin of your plane is going to be the mid-point that you calculated and the vector should be the normal of the plane to make them parallel. Such that:From here, I would make an opPlane off of this:
<div>opPlane(context, id + "plane", { "plane" : planeDef, "width" : 6 * inch, "height" : 6 * inch });</div><div></div>Then you want to make a sketch based on this planevar mySketch = newSketch(context, id + "sketch1", {<br><span style="font-family: Flama, sans-serif;"> "sketchPlane" : qCreatedBy(id + "plane", EntityType.FACE)<br></span><span style="font-family: Flama, sans-serif;">});</span>Since you already have the mid-points, I would use the cPlane command with the cplaneType set to CPlaneType.MID_PLANE.
