Constraints: Where two curved lines meet
I'm noticing that my circles aren't connecting straight.  Is there a constraint that I'm missing or something I should be doing to straighten this out?  Here's a link to the public workspace http://bit.ly/2cCOrOj.
  • mahirmahir Member, Developers Posts: 1,319 ✭✭✭✭✭
    edited December 2016
    Your workspace is view only, but I imagine you would need a tangent constraint between circles before you patterned
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    What you are looking for is the tangent constraint when you are sketching. The hotkey for this is "t"
    https://cad.onshape.com/help/index.htm#sketch-tools-tangent.htm?Highlight=tangent constraint
    Twitter: @bradleysauln
    After copying your public doc and looking at the workspace it looks like a fundamental error in the sketch. The goal is to end up with both arcs created to be tangent but the way you've constrained them is preventing that.
  • robert_wells594robert_wells594 Member Posts: 7
    Thanks! Any suggestions on how I should have created them?  I'm going by trial and error and learning as I go.  Sorry to ask the newbie questions.
    I would start with 2 tangent semicircles positioned and constrained exactly how you want. Make sure you control the angle it takes up. For example, if you want a pattern of 10 knurls, make sure the end points are 36deg apart. Next, create a circular sketch pattern. Voila.
