Is it possible to have a part studio window open and an assembly window open at the same time
OS Professional Posts: 188 ✭✭✭
I am used to working where I have a window open that has the entire assembly visible and a second window that has just the part I am working on. I like to work in the window with the isolated part but see the updates in real time to the assembly window. Does OnShape allow this?
  • Member, Developers Posts: 1,314 ✭✭✭✭✭
    You can definitely do this. You just have to load the same document in two different browser windows with a different tab open in each window.
  • Member, Moderator, Onshape Employees Posts: 315
    edited October 2016
    Even easier than that, right click on any tab and select "Open in new browser tab"!
    Onshape, Inc.
  • OS Professional Posts: 188 ✭✭✭
    Awesome. And I was surprised to see the that changes in one window were reflected immediately in the other window without having to refresh. :)
    It might be an enhancement request to make OnShape know that both browsers are from the same desktop session....so that you don't see yourself as a double editor.
  • Onshape Employees, Developers, HDM Posts: 1,227
    Seeing yourself as a "double editor" can be useful -- you can double click on the collaboration icon to synchronize the view to the other window (follow mode).
