How to copy an assembly within the same document
Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 267 ✭✭✭
edited October 2016 in Community Support
This question handles about copying an assembly within the same document. I asked the question below earlier in the wrong category (Using OS), so it is not marked as a question. That's why I repeat it over here.
bradley_sauln suggested earlier to have a look at https://www.onshape.com/cad-blog/tech-tip-how-to-use-linked-documents
However, if I understand the tech-tip correctly then one can linked a copy to another document. I want to have a copy of the assy in the same document.
Let's assume the name of the parts in the Onshape document above Velg = A, Band = B, Velg = C, Spaak = D.
I like to have Assy_Voorwiel, which consists of parts A1, B1, C1, D1 which have the same shape as parts A, B, C, D with different dimensions.
In the world of file based CAD-systems it would be like this:
  1. Parts  A, B, C, D are in Assy_Achterwiel.
  2. I make a copy from Assy_Achterwiel to Assy_Voorwiel and the CAD-system asks if the new assy should contain A, B, C, D or new copies A1, B1, C1, D1. I like to have the latter.
  3. Now I have a new assy (Assy_Voorwiel) with new parts, still equal to A, B, C, D but changeble to other dimensions.
In OS I copied the part studio, so I have the new parts (A1, B1, C1, D1) already. But now, how do I get Assy_Voorwiel in document Benz so that I do not have to build a new assy from parts A1, B1, C1, D1?
Wiel.jpg 208.8K
  • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 267 ✭✭✭
    shashank_aarya, this is, although a little bit devious, a good workaround. Thank you.
