How do i stick fins on a cylinder in an assembly?
matt_farkas
Member Posts: 8 ✭
Extruded a circle to make a (hollow) cylinder. Don't see how to add mating connectors in the extrude. In the sketch, it's just a circle.
Made a separate fin part.
Yah, I'm new to CAD and Onshape.
brian_brady
Member, Developers Posts: 505 EDU
Take a look at this:
https://cad.onshape.com/documents/57f7fa10d9d05d10ebf605a2/w/bb4e37435a2021c1dc41b888/e/4e6237a1c9b69c38a0630c9b
I placed 4 mate connectors on the tube by first adding points to the initial sketch. I realigned 3 of the connectors to make the z-axis for each normal to the tube. Then in the assembly I used those connectors to add the fins.5
Onshape, Inc.
https://cad.onshape.com/documents/64fc2f49c879e9a688bb3444/w/9b3173d52b7fe439b8b0c941/e/51853d910634b3a7b3a63cbb
Onshape, Inc.
but then how do i add more fins higher up? do i have to extrude the full length then cut out what i don't want? even the current drawing is wrong in that the real fins have a flat edge that will be welded, but in parts studio it made a nice curved edge...
if assembly is all about moving parts, why have the fasten option?
so i guess you're saying there's no way to stick fins on a curved surface in onshape?
