Section view with mobile device
How can I take a section cut thru a view on mobile device. The small box is not visible.  But I can see it on my laptop.
    brian_bradybrian_brady Member, Developers Posts: 505 EDU
    Just tap on the view cube that is there. On a mobile device the view cube has the menu that the smaller cube has on your laptop. Last item is Section View.
    shai_perednikshai_perednik Member Posts: 56 ✭✭
    Just checked and I don't see section view there.  I've been looking around for a while.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,442
    If you scroll down you should see it at the bottom
