Getting assembly studio information back into part studio?
I've used assembly studio to line up parts from two different part studios.
Now that I have their alignment I need to get that alignment info ... points or something ... back into part studio so I can design the mating hardware.
I don't immediately see how to do that.
Any suggestions?
Any suggestions?
Onshape, Inc.
I know I've kept you busy with all the STL questions but now that I have the STLs imported and positioned, I am now back to working on the actual design.
Any suggestions for capturing points of interest while moving the kinematics through its range of motion? Then using those to optimize the original mechanism geometry?
Robert
I also think using Mate Connectors (which are just coordinate systems, really) and transform features would work well, but it depends on complex the motion is. Is it possible for you to share the geometry with us?
Linked[in]
Onshape, Inc.
