Don't think OS is good for me
Josy_LaJosy_La Member Posts: 82 ✭✭
Hi to all,
For many reasons OS does not seem to have the capacity unless I just don't know how to best use the platform.
When importing/inserting a dwg in a sketch the cad block is exploded...not good
I can't insert at specified workpoint since they all collapse on origin...strike two
Using transform combined with variables and formulas to relocate sketch does not adapt when variable is change...hum!
What I need and maybe someone can point me in the right direction is the following:
1) I have to be able to insert and reuse profile sketches (blocks) from a custom library on specific points located on a wire frame.
2) Many profile will be inserted on multiple views before they are extruded; those sketches must remain on point when wire frame dimension changes.
Simple enough but can't seem to achieve desired result.
    Have you tried to derive sketches and manipulate position with mate connectors?
