How to intersect two pipes?
allen_bradley
Member Posts: 5 ✭
I am new to this so please forgive me if this is obvious. I have searched the tutorials and forums without finding an answer.
I am trying to draw an intersection of a 50 mm pipe with a 100 mm pipe at a 45 degree angle. Both pipes have a 3 mm wall thickness.
1) How do I remove the part of the 50 mm pipe inside of the 100 mm pipe?
2) How do I remove the elliptical hole in the side of the 100 mm pipe where the 50 mm pipe intersects? Thanks for your help.
henry_feldman
Member Posts: 131 EDU
Do you mean something like this?
https://cad.onshape.com/documents/cce1eb35b77b06ecf130d0d8/w/a49d0620d02631e4b9c359cb/e/1c1112a5d7c8ebcbbe8a8cdf
All I did was extrude a pipe then extrude a remove circle the inside dimension, then made my intersecting pipe and same thing...5 -
allen_bradley
Member Posts: 5 ✭
Yes! Thank you. I knew it would be simple. I had to check "Merge with all" to get it to work. I was expecting the cuts to be "automatic" somehow. I never thought about a separate cut after I extruded my pipes. Thanks for your help.5
