Solidworks feature library
Does the equivalent exist in OS? This is one of the tool I miss and can't seem to find it in OS. I'm trying to build a library of custom 3D cut out that I could reuse as needed and can easily be inserted using vertex.
Onshape, Inc.
Don't worry that featurescript isn't your thing - you don't need to write a single line of code to use custom features!
also - it sounds like derived sketches is what you want.
Ideally I want to click on a custom feature button that does exactly what is expected each and every time I need it. This means derive a sketch from a library and extrude remove material on one or multiple parts based on a point I select on screen. Can this be achieved and where can I find guide lines to help a non programmer like myself? This is doable in Solidworks and Inventor without having to write our own codes; simply by extracting features and applying them based on references.
