help with extrude
Hi
I wanted to add a tank on the tube that i build so I make an extrude (remove) and a extrude (add) but when I did it the tank started from the middle of the tube and not from the outside of it.(like in the pictures)
How can I fix it?
How can I fix it?
ofir_shapira Member Posts: 4 ✭
Hi thank you for your answer I tried it but it doesn't workthe first option was the same as before
but the second removed the extra tank that I don't needbut it make a hole in the tube.
thanks
Ofir5 -
owen_sparks Member, Developers Posts: 2,660 PRO
Hi @ofir_shapira, I'm still not cleat exactly what you need but I believe your sketch is located on the plane in the middle of the tank? Is that correct? If so that is why the tank starts there.
What I was suggesting is to make a new plane outside the tank.
(a) Create new plane outside tube. Use the "offset plane" with the existing plane in the tank as the reference to offset from.
(b) Create a new sketch on this plane with the rectangle on it.
(c) Extrude this rectangle "up-to" the tube.
Feel free to share the document and I'm sure you'll get the help you need.
HWM-Water Ltd5 -
Narayan_K Member Posts: 379 ✭✭✭
@ ofir_shapira , It sounds like you want to remove inside material from the tube. If so then
1. select extrude- make it "remove" (by default it will be "add"
2. select the the face which wanted to remove(select the face which highlighted in second image).
3.select the option "Through all" from the drop down menu.
4. press green button from dialog box.
5
(1) You could make the tank with the sketch outside the tube then use "extrude up to part" or "extrude up to face" option.
or
(2) Keep what you have and use another extrude remove to get rid of the bit you don't want.
Cheers,
thanks
Ofir
thx.
I have another question in a different subject.
I want to remove the circle in picture so that will open with the tube below(there will be water there so they could pass)
how can I do it?
