How to import parts into existing Part Studio? Or, how to edit Parts within an Assembly?
Hi, need some help!!
What do I want to do: Create a housing for electronics based on step file of a pcb. It needs holes for push buttons, connectors and other component related stuff.
My workflow: Import pcb, build the housing referenced to planes, edges, centers etc. of the electronic components. So far everything works perfekt! Housing with bottom, hood, cut outs is fine. The pcb had to be changed due to some geometric issues. So i need to modify my housing.
My Problem: I need to reference sketches etc. of my Part Studio to the new imported step file of the new pcb. But this comes together only as an assembly! So I don't see how to edit my parts referencing to the newly imported pcb. How is it going? Can I import my pcb as a part into my Part Studio?? Can I edit parts in the assembly?
Thanks and regards, Axel
2
It sounds like you are doing some in context modeling. The best way to go about this is:
1. Import the new PCB into another part studio tab.
2. Go to your original PCB Housing tab.
3. Use the derived command (found in the feature tool bar). Select your newly imported PCB.
You'll want to move the derived part in the feature tree to the top of the feature tree. This way you can change you references in your sketches.
Hope this helps.
thanks, works good, again one day I learned something new and usefull
thanks caseymatalone, againe learned something new
