help with extrude
Hi
I wanted to add a tank on the tube that i build so I make an extrude (remove) and a extrude (add) but when I did it the tank started from the middle of the tube and not from the outside of it.(like in the pictures)
How can I fix it?
    If I understand you correctly:-
    (1) You could make the tank with the sketch outside the tube then use "extrude up to part" or "extrude up to face" option.
    or
    (2) Keep what you have and use another extrude remove to get rid of the bit you don't want.
    Cheers,
  • ofir_shapiraofir_shapira Member Posts: 4
    edited October 2016
    Hi @owen_sparks  I think you don't correctly understand the tank has the tube shape(it isn't rectangle) and I want that it will be on the tube and not inside it
    thx.
    Hi @Narayan_K I succeed thx.
    I have another question in a different subject.
    I want to remove the circle in picture so that will open with the tube below(there will be water there so they could pass)
    how can I do it?
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @ ofir_shapira, Please find the below video,
