resize STL by specifying a value for an edge/etc?
florian_ford
Member Posts: 54 ✭✭
Hi guys, I have a STL-related question as I start importing STLs into onshape...is there a way to tell onshape that "this distance is 20mm -> resize the whole thing accordingly" ?
bradley_sauln
Moderator, Onshape Employees, Developers Posts: 373
You can modify the units of the imported mesh file: https://cad.onshape.com/help/#mesh.htm?TocPath=Importing%20%26%20Exporting%20Files|Importing%20Files|_____15 -
paul_chastell
Onshape Employees Posts: 126
Also you can use the transform feature on meshes. You can move them, rotate them, and you can scale them. You can't put a measurement from the mesh directly into that feature but here's what I would do if I had to scale a mesh in a way other than changing it's units.- Select the two points that I know that I want to have a certain distance apart
- In the measurement area in the bottom right the distance is now shown (as when selecting points of regular solids).
- A bit of math to work out the scale
- Use the Transform feature to scale the mesh
Paul Chastell
TVP, Onshape R&D5
Twitter: @bradleysauln
TVP, Onshape R&D
