Can anyone help me with my electric motor concept?
Okay so my motor concept involves two vortexes that are in the center of a torus. Also I'm trying to make this with a proportion of phi. So I started with the vortex. I created the proportions on a flat surface. Which looks like a vortex. But to extrude the object only make it in a flat surface. I need to have offsets to the proportions that I set out. But when I draw a line from the flat dimension to a 3d dimension. The lines stay in the flat plain. Nothing can be highlight for exact measurements a well.
mahir Member, Developers Posts: 1,316 ✭✭✭✭✭
I made something close to what you're looking for. You can probably modify it to suit your needs.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/396546bb7d9f32aab9f2fd41
6
