how to get dimension?
papawopapawo Member, Developers Posts: 206 PRO
edited October 2016 in FeatureScript
  • papawopapawo Member, Developers Posts: 206 PRO
    is this possible?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,245 image
    Sorry, I'm not following what you're asking. The dimension the diagram seems to be asking for is labeled "3 inches", so you know that value... Perhaps if you posted a link to a public document with a custom feature that's producing something close and a sketch that is what you want, we would be able to help better.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,902 image
    It's not entirely clear what you're trying to do. evDistance will give you any measurement you need. If that's not what you're looking for, please explain the purpose of the feature you're creating and we may be able to suggest a way.
    edited October 2016
    the 3" varies and depends from point to converted line,
    the 1" is fixed dim.
    and the 4" varies and depends on the first dim (3").
    this can be skrectangle or sklinesegment.
    So are the 3 blue lines all the same length?
    the top blue line is fixed dim and not the same length as the 2 vertical line.  it can be any dim from the point.
    So evDistance will give you the distance between the point and the line, then you have the coordinate of the bottom left corner, relative to the point.
    Thats my problem, I dont know how to use evDistance.
    var distance = evDistance(context, { "side0" : <query for point>, "side1" : <query for line> }).distance;
    if you don't know how to query the point and the line, you'll have to share your script.
    definition.line and definition.pt are already queries so no need to query them again.
    var distance = evDistance(context, { "side0" : definition.pt , "side1" : definition.line }).distance<span>;</span>
    edited November 2016
    ok thanks
