Public launch of OnShape
kevin_quigley
Member Posts: 306 ✭✭✭
in General
it appears, if the press releases and Twittersphere are correct, that OnShape will be publicly released at Develop3D Live at the end of the month, with delegates being invited to try out OnShape using their laptop, tablet ot phone.
this is a hard core audience so it will be intersting to see how this pans out in terms of bandwidth capacity and acceptance of the feature set. I'll be there!
A 'modeling battle' between attendees using Onshape on their mobile devices. The fastest and/or most accurate modeler wins 1 year of Onshape Pro. How far am I off?
Dries
Dries
What about lifting the veil just a tiny bit...
Dries
Right now we are working very hard towards a number of significant date milestones (Develop3D is just one of them). The work environment right now is a cross between DefCon5 and a Rave party (just kidding, everyone here is a quiet professional) - no seriously, the music is deafening. The more attentive members of this group (@Dries) already caught a bug that let slip that we were working on drawings and all i can say right now is that it will be a little longer - just bear with us. With regards to stability - this is (in part) a function of our architecture. If something bad happens in one instance of some service that you are running on, then we just jump you over to another fresh one. 9 out of 10 times you will not even notice (worst case you just refresh your browser). This is an inherent advantage of cloud in general and of the Onshape solution in particular. Exciting times
Not rushing things is the best way to do it. You don't want people turning away because of constant crashes or bugs. Stability is key.
Dries
Very impressive the way you guys are keeping steady heads. Given how you guys are bidding fair to kick over the barstools and clear the MCAD saloon (apologies for the hyperbole) it would be easy for a less grizzled bunch to let their enthusiasm reign over their good judgement.
I've never had any previous inclination to participate in a software beta program (and no lack of opportunities, over many decades) but I immediately sensed this one would be very different ... so I dove in with confidence ... and I'm pleased to find 'so it was'.
