Glass for Windows for .stl part
charles_harris178charles_harris178 Member Posts: 15 ✭✭
edited November 2016 in Community Support
Hi
A wall has several windows ( a small model to be printed) I want only the inside of to make a separate part to be printed in clear for windows.   The part will be a strip along the inside of the wall covering all window spaces, at each window space the strip will go into the space level to the outside edge, (like taking a mold)
Windows all same size.  How do you get the glass  insert to fit the existing space.  Needs to be a sliding fit (not tight)
Thanks
Charles Harris
  • charles_harris178charles_harris178 Member Posts: 15 ✭✭
    Hi
    Thanks for the info.  I will give it a try.  I see now how to make a sliding fit etc
