Making a beehive
irene_rivers
Member Posts: 17 ✭
I'm trying to make a beehive in the form of a hexagon.
My current plan has been to trace a beehive pattern, use the spline tool, trace the holes, and extrude them.
This is the image: http://previews.123rf.com/images/alexandrmoroz/alexandrmoroz1206/alexandrmoroz120600016/13894400-black-honeycomb-pattern-isolated-on-a-white-Stock-Photo-hive.jpg
However, this also means that I have to use the line tool to trace over the other parts of the pattern to form a shape.
My current design technically works, but I rather have the beehive to be more symmetrical, so as to make it more aesthetically pleasing.
I've made the document "Beez Nuts" public, so please feel free to come check it out and give me any suggestions!
Does anyone have any ideas on how to make each hole the same size and be of equal distance from each other?
The holes near the edge of the hexagon should still be full size.
Thanks
Thanks
NeilCooke
Moderator, Onshape Employees Posts: 5,927
You also might want to take a look at onshape.com/featurescript where you'll find a fill pattern feature or maybe even the hex infill feature.Senior Director, Technical Services, EMEA7 -
bruce_williams
Member, Developers Posts: 842 EDU
I took a stab at this. First, I put the picture on a separate sketch so it can be hidden and I added a dimension to constrain it. Then on a new sketch, I used the polygon sketch tool to make a true hexagon over the picture, offset that for wall, extruded the first cell, and then used linear part pattern & transforms to fill in the grid. The size & spacing needs to be tweaked...I did not spend the time to get it perfect. fun exercise!
see document at https://cad.onshape.com/documents/582e61c1a68076104d334eca/w/1780d3996a8c1d70999996f3/e/b61818da9bbcc6ab7d43c9b4www.accuratepattern.com6 -
TimRice
Member, Moderator, Onshape Employees Posts: 315
Looks pretty good Bruce. I took a try at it here:
https://cad.onshape.com/documents/582e971221ea7b10345a2249/w/ca7d300287d1128b38bb4b8c/e/7bce4e89fe9ff0424b687aab.Tim Rice | User Experience | Support
Onshape, Inc.6 -
TimRice
Thanks Bruce! We usually recommend using a face or part pattern as that will give you the best performance. Sketch patterns tend to slow down the document at very high sketch entity counts (which can happen easily with large patterns). I made the doc public so you should be able to copy it!Tim Rice | User Experience | Support
Onshape, Inc.5
Onshape, Inc.
Onshape, Inc.
A couple questions -
1) What is best practice on patterns? The honeycomb could be sketch pattern, feature pattern, or part pattern.
2) Could you share your document with copy permission? I would like to go through it.
Onshape, Inc.
Finally, use the linear pattern tool to copy the tube into a honeycomb. All the offsets can be measured from the sketch.
See image below, or public document 'Honeycomb Experiment'
Seems to work ok.
