Plane Question
papawopapawo Member, Developers Posts: 206 PRO
This cant be extruded because of evOwnerSketchPlane
Do I have to create a plane for this?
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,435
    evOwnerSketchPlane is looking for a query for an entity from a sketch, not the sketch itself.
    You could use the same definition you used in "sketchPlane" on line 12, or query a face from the sketch.
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,178
    The problem is that sketch1 is a "sketch object", while what you need is a query for the entities created by a sketch.  So if you use qCreatedBy(id + "sketch1", EntityType.FACE) in both places in opExtrude, it should work.
    For future reference, posting a link to a public document version is best, but pasting code as text is preferable to pasting a screenshot of code -- because with a screenshot, we can't copy your code to test it.
    oh okay..
    thank you!   :#
