Gear relation doesn't rotate when i play an revolution mate
bart_laarkampbart_laarkamp Member Posts: 1
edited November 2016 in Community Support
I have two shafts parallel to each other, connected the with an revolution mate to an base-plate that is fixed in space.
i would like to show how these two shafts rotate. I have an gear relation between the two revolution mates.
I hope this all makes sense..
With kind regards Bart (NLD)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,932 image
    Are there any keyways or anything on the shafts that make it easier to see if they are rotating? If you post your public doc URL I can take a look.
    @bart_laarkamp,If your both shaft rotate independently then I feel this is problem due to your relation ratio in gear relation. Please put those two shaft diameter ratio as a relation ratio. I feel it surely work after applying correct relation ratio. If it not working please post your public doc URL I can take a look.
