Help with specific Extrude or Loft on a part?
jannie_van_der_walt
Member Posts: 6 ✭
Hi All,
Hope I can return the favor one day.... I need some help understand how to do an extrude on a specific part.
I have a specific part I am drawing out, it's a "Cover" for a Tow Hinge of mine which got lost.
https://cad.onshape.com/documents/e35f11ab92fb9fa28c7619e1/w/4064d2247eb2eab93b9b7328/e/3454514cfb4cc2004a43dd8a
This is where I am at the moment:
I am trying to figure out how to "Extrude" or "Loft" the part in yellow so that it becomes part of the "Part".
Any guidance would be greatly appreciated.
Thanks in advance,
Jannie
Thanks in advance,
Jannie
Sketch on front plane, convert sketch of the triangle and extrude up to face in both directions. Hope this is what you needed to do.
But starting from scratch:
Create 2nd profile using a surface:
Loft between profiles:
I suppose I could do a draft where the two faces are "off center" as I need the one edge to be flat.
Thanks again!
