Concurrent login limit?
luke_jaeger100
Member Posts: 34 EDU
Hello, I'm going to be teaching an introductory CAD workshop (14 students) next week using Onshape. Instead of spending class time on getting 14 individual accounts set up, we thought we'd set up one generic account and log into it on all the classroom computers, so it will be ready to go when the workshop starts. Will this work? Is there a limit on concurrent logins to the same account?
Each student will create and edit their own document - it's not going to be a 14-person collaboration - that would be a train wreck.
I suggest one of you taker five minutes create a team and add 14 users to that team. Onshape internally creates accounts and send activation emails to team members. Only thing members need to do is setup password and activate account. That should take few minutes and helps you a lot in the long run.
However, accounts are meant to be individual and that is the scenario we test.
That said, we are certainly not concerned about your use case. It is up to you how to teach you intro class and to determine what approach will work best for your situation.
It may not be possible in your situation, but we have done intro courses in a couple ways in the past. One - we set the students up at the beginning of the class having them follow along. It typically just takes a minute or two. Two - we send them email before the class with simple instructions to set up their account before the class and even create their first document. At the end of the class, we also like to show a couple of unique features of Onshape, like how easy it is to invite a collaborator, set permissions, and that collaborator can get going immediately - as this is very easy in Onshape and very hard in installed systems.
Again, thanks very much for teaching Onshape! These are just suggestions - however you choose to help expand the Onshape community is up to you and much appreciated!
