How do I do multiple distance mates in Onshape?
asyraf_saaet
Member Posts: 3 ✭
I'm trying to mate a specific part on a base plate where the precise distance from the datum is key. Therefore, I'll have to use 3 mates to lock it in place. On the plane is easy but for the X and Y is not as clear cut as in Solidworks.
bruce_williams
Member, Developers Posts: 842 EDU
You will be able to accomplish what you describe with one Fastened mate between mate connectors. In Fastened dialog, click offset and enter the x,y values. OR create mates at the locations required in part studio. see the attached picture and OS help Mates - https://cad.onshape.com/help/#mate.htm?Highlight=mates
www.accuratepattern.com6 -
viru
Member, Developers Posts: 619 ✭✭✭✭
@asyraf_saaet, Yes you can do it by giving mate constraint with respect to two / three faces with the help of planer offset. kindly refer below video for more detail.
5
Offsetting entities from one another during assembly is available for the following mate types:
You can also drag the entities and observe the distance values in the graphics area. These can help determine the specific values to enter in the dialog.
Please refer below video for more detail.
