Editing on Assembly?
marco_dammarco_dam Member Posts: 1
edited December 2016 in Community Support
Hi all, I'm working on a little project, a 3D model of a wooden cabinet...
I made the assembly using various parts, most of them are repeated (import same part a lot of time), now I should use an extrude cut through all, I can't edit every single piece, LITERALLY CAN'T!!
Is there a way to edit the assembly? Export as an editable part? need help..
