Part vs Part Studio
adrian_vlzkz
Member, pcbaevp Posts: 302 PRO
I have a good understanding now of how Onshape does Parts, BUT... I'm having trouble explaining to our SW users how Onshape is structure compared to SolidWorks or other CAD packages. I think it would be a lot more intuitive to rename Parts (Bodies, if you come form SWX) or the "Part Studio".
Building Parts inside Parts is traditionally asking for trouble
, I understand that is not the case here, but for new users it turns on a red flag automatically.
Maybe if either the Part Studio is referred as "Component Studio/Tab" or the Parts themselves as Components or "Pieces" in a Part Studio, it would be a lot less confusing for new users.
CAD Engineering Manager
In Onshape, one Part Studio has one parametric history that can drive many parts. And those parts are really parts - that can be naturally instanced multiple times in multiple assemblies. In the assembly they can move relative to one and other - whereas in multi-body parts in traditional systems - the bodies are rigid relative to one and other.
So as @bruce_williams says, the terminology Onshape uses accurately defines how Onshape is different and better. In traditional cad systems, the use of the term body is also accurate - because they aren't parts and cannot be instanced in assemblies.
The problem is similar to creating perfect folder stucture with traditional cad.
I suppose it wouldn't harm if Onshape would create example guide on how to divide stuff into docs, studios, etc..
ps. There are several reasons for changes in my workflow: of course first going pro with no limits on amount of docs, updates like linked docs, tab folders etc.. And I'm sure configurations will turn my world upside down once again..
My concern is that currently version control is applied at the Document level so multiple Part Studios that have multiple "Parts" don't sound like the best idea for our environment. Like @3dcad mentioned, some guidelines on that is the preferred or designed approach would help.
