Simplified Loft Guides Problem
jon_woellhaf
Member Posts: 92 ✭✭✭
In this document at
https://cad.onshape.com/documents/5864a92dbdf38910333ad9d4/w/f291f345b61a6ebd56fbeb0a/e/0aec76a0249cfffad54566f4
Why do the horizontal guidelines work and the vertical guidelines not work?
I have spent several hours working on this problem and have run out of ideas.
mlaflecheCAD
Member, Onshape Employees, Developers Posts: 198
The loft sections did not need to be broken up the way they were; a single ellipse path was all that was needed. I converted your 4 segment sections to construction entities to preserve the relationships and created new sections that were simplified and that is all that was needed.
Here is the document:
https://cad.onshape.com/documents/586504d85107771048741e58/w/2d86e449a0b7d6810aed93e3/e/1ff1974b5127cd24c5a23026Regards,Mike LaFleche @mlaflecheCAD6
Thanks very much!
Jon
