Problem with USE tool
I'm unable to select any entities from sketches other than the one I am editing. I think I should be able to select entities from other sketches and utilize the USE tool to use in new sketch. Thanks.
If you move you sketch Front after "SpokeInward" in the feature list you can achieve this.
This is how parametric modeling works. The geometry is a result of replay of the instructions recorded in feature tree. The dependencies in these instructions can only flow one way.
