assembly degrees of freedom
jonathan_mizrahi827
Member Posts: 5 PRO
Is there a way to see if an assembly is fully constrained, and if it's not, to identify its degrees of freedom?
Optionsviru Member, Developers Posts: 619 ✭✭✭✭@jonathan_mizrahi827, I think you are looking like degrees of freedom analyzer available in Autodesk inventor. Currently this facility is not available in Onshape. You can raise improvement request for this. In near future we hope that this facility will be provided by Onshape.
Autodesk Inventor:- Whenever you apply a constraint to a component in an assembly, you remove one or more degrees of freedom. A component is fully constrained when all degrees of freedom (DOF) are removed. You are not required to constrain completely any component in an assembly in Autodesk Inventor.To verify the DOF of components in an Autodesk inventor assembly we can check by two method.
- Select Degrees of Freedom from the Visibility panel of the View tab.
- Drag a component in the graphics window. Other components in the assembly move, based on existing constraints.
5
Hope this helps,
Noa
More generally, if I have a large assembly consisting of many parts and many mates, it would be very helpful to be able to see, across the entire assembly, where it is not constrained.
