Making loft shape
Dear Onshaper,
https://cad.onshape.com/documents/69a0c2f4ded21508bfc90699/w/652b9d367f030d3d8da538df/e/f889a33dfcb60c6aa22c1f54
I want to make solid or surface model. but I have failed the loft function.
Could you have any ideas?
Profiles. From back face profile to vertex at the centre point on the front arc.
Guides. Changed to splines, point to point rather a combination of lines and arcs. I also mirrored the spline on sketch Edge???2 so there are 2 splines symmetrical. Selected the 3 splines as guides and pushed the loft out to shape.
https://cad.onshape.com/documents/586f334e7a21aa10e5485cfa/w/ca92af99d8e9e1543ef4af4f/e/be08be2a2a9892af295d5a92
Hmm, couldn't we use the line segments not spline as Guide?
I tried this as well and Bruce's solution is very good.
My contribution here is to state that you absolutely can use multiple sketch entities as a guide curve - the secret is to put them all in a single sketch and then select the sketch as the guide.
I love Onshape
I have just redone the model to see this work but unfortunately, it doesn't generate after selecting a combination of sketch 2 or 3 on the bottom plane. Any idea's on this.
https://cad.onshape.com/documents/586fb81979772510f11d29a3/w/2f65ee13843591ca2d3cb09e/e/69051890f39a5bfdaf18f271
