Problem with assembly (slider mates)
Hello,
I have some questions/problems with slider mates. I try to create a shelf of aluminum profiles. The individual shelves should be adjustable in height.
For this I tried to attach the shelves to the stands by 'slider mates'. The first slider mate also works, but the others lead to errors or the display of 'red' slider mates.
What did I do wrong? How can I tie the stands or the (grey) ground to a plane (for example top plane)?
here is the document (https://cad.onshape.com/documents/586a615b0e11ad10b6a1aa7c/w/a8bab8f023590086b19a298a/e/67f4f95a74a1c4afaceea7d9)
Best regards
Ralf
Best regards
Ralf
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
Hi Ralf,
I had a little play with your assembly. I also found you could not have multiple slider mates working on each of the verticals. I ended up using the slider mates to position the verticals then suppressing 3 of them as well as the all the verticals planar mates and group mating them to the base plate. I also Fastened mated the base plate to the origin.
Seem to work as desired, the only issue with this I can see is if the base of the regalboden changes, the group mated parts will not move with it, you could overcome this by removing the group mate, unsuppressed the first 4 planar mates and adding 6 more planar mates instead of the sliders mate 2,3 & 4.
https://cad.onshape.com/documents/5870c55569ca5410c4d3f861/w/7cf9b0aede17dbc920c32584/e/2a6d334da01ad7520e81ce46
5 -
viru Member, Developers Posts: 619 ✭✭✭✭
@ralf, I corrected your part and given some mate constrain to your assembly. Please refer below link document for more detail,
https://cad.onshape.com/documents/58762072c986e117b0a0bec0/w/ba5185f2fe1537e7342e460e/e/7f4b161d3830b033c7892309
Also refer motion video of your assembly after defining all constrain,
5
thx for your help. I couldn't open your link 'Failed to load document for workspace. Ressource not avaible or you do have the needed permissions'
https://cad.onshape.com/documents/587484ba0dbf5317c8fc8d5e/w/654fe3bf77ed87f324750eb4/e/ab3b94d453fa0b5ace62d8ea
Kindly correct this part then you will get desired result. If then also you feel any problem then feel free to ask us.
You are observing failure of sketches (Sketch 1) due to missing of sketch plane which you previously selected face of "Nutstein I-Type Nut 5" part as sketching plane. This part face changes due to edit in Extrude 4. Therefore you have to again select face of "Nutstein I-Type Nut 5" part. After that you have to define reference again in sketch for dimensioning.
You are observing failure in Extrude 5 due to failure of sketch 1. After solving sketch 1 and selecting circle your extrude 5 surely work. Due to "Nutstein I-Type Nut 5" part you will also failure in subassembly and assembly mate constrain.
I corrected all above changes yesterday itself in below link document. Kindly refer it and check all part and assembly tab.
