Measurements within an assembly
Does there exist a way to query entities in an assembly to determine distances between points?
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
You should be able to measure between points within an assembly by selecting them and looking down at the bottom right corner. The little arrow on the right will give a popup with more detail. Pressing the spacebar before selecting the points will clear any previous selections.
If you are looking for a way to parametrically link a mate dimension/value in an assembly to another there is no way to do this that I know.5
Thanks!!!!!
