Copy assembly
icatoiu_daniel
OS Professional Posts: 4 ✭
Hi all,
Do you know if is possibile to copy an assembly to onother document.
Thank's:
Thank's:
viru
Member, Developers Posts: 619 ✭✭✭✭
@icatoiu_daniel , Currently this facility is not available for assembly and drawing in . User can copy only part to other document. This is highly requested improvement to Onshape. You can vote for this in improvement request as shown in below path.
https://forum.onshape.com/discussion/1687/copy-parts-and-assemblies-into-different-documents
In future we hope that user will able to copy assembly and drawing tab also to other document.
5 -
shashank_aarya
Member Posts: 265 ✭✭✭
I think following could be the easiest workaround. Only thing is it will not copy to new document, but it will move the assembly along with associated part studios
5
I'd like to be able to at least be able to copy an assembly comprised of inserted parts from other documents.
Having a document housing a parts library doesn't work very well if you can't link to the parts contained within the library. Having to redraw similar assemblies in other documents because you're unable to copy an assembly over isn't fun either.
You just copy the work space (three line button, top left corner) that has the assembly you want to move, then either move that assembly to your new document or move it into a new document of its own. It's not most streamlined way to do it....but it works.
