Background color
I am brand new to onshape and decided to start using a tutorial. I want to follow along with my own exercise so I made a copy. The background is BLACK and the plane lines are blue. I also can't select a plane to sketch on, etc., etc. Basically I can't even get started.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,919 image
    @philip_carney are you using chrome Firefox opera or safari? Those are the only supported browsers. Also make sure your browser and graphics card drivers are up to date.
    To add to what Neil said,  you can use this tool to determine if your browser and graphics card are compatible with Onshape:
    https://cad.onshape.com/check
