Turning a 2D cross section into a 3D drawing
 ryan_lusher
                    Member Posts: 3 ✭
ryan_lusher
                    Member Posts: 3 ✭
                    Hello
Looking for some help. I am a cable draughtsperson. I draw out cross sections of cables all day but was wondering if there is away using Onshape to convert them into a 3D drawing. There doesn't have to be twists or anything. I just need help designing it as I have never really used any 3D drawing packages before. It would be good if I could show a bit of each i.e. the copper, then the insulation, then the sheath material. Like in a layer I guess is the best way to describe it. Any help would be much appreciated.
Thanks in advance.
Thanks in advance.
             bradley_sauln
                            Moderator, Onshape Employees, Developers Posts: 373 bradley_sauln
                            Moderator, Onshape Employees, Developers Posts: 373 You might find this tech tip to be useful: https://www.onshape.com/cad-blog/turning-your-old-2d-drawings-into-3d You might find this tech tip to be useful: https://www.onshape.com/cad-blog/turning-your-old-2d-drawings-into-3d
 Let me know if you have other questions.5
Twitter: @bradleysauln
