Curve XYZ tool?
![4DeltaEDU](https://cad.onshape.com/images/placeholder-user.png)
I am trying to create an airfoil section using airfoil data points X Y Z coordinates from excel spreadsheet. In Solidworks for e.g there is a tool Curve XYZ, where you can insert data and the points will draw automatically on the plane of your choice. Is there such a thing for Onshape?
Many thanks!
Many thanks!
http://www.mh-aerotools.de/airfoils/index.htm
Here you find a tool (concord) that converts xyz-coordinates to dxf and similar.
