Apple Mbile Device Compatibility & Fnctionality
Bluchip
Member Posts: 20 ✭✭
Hello,
I am curious as to Onshape and how well it functions with Apple mobile devices. I had used the software in limited basic functions with an iPad Mini. All seemed well. However, Onshape has determined to not support that device (if I understand correctly). No issue, it's a rather small device to design with but it was convenient to view/demonstrate projects.
That said, what Apple mobile devices are supported and intended to be supported into the future? Specifically, will there be support for iPad pro? With the intro of a 12.9 iPad pro, this is a viable device to actually design with. How well does Onshape interface and is this going to be the case for the foreseeable future?
NeilCooke
Moderator, Onshape Employees Posts: 5,929
Hi @Bluchip - Onshape supports all 64-bit iOS devices, especially iPad Pro with Apple Pencil.
https://www.onshape.com/cad-blog/cad-for-ipad
Senior Director, Technical Services, EMEA5
Thank you!
Onshape is incredible on the iPad. Performance is far superior to the browser version.
