Measuring diameter
For I have been experimenting with some drafted circular extrusions, and selecting the circle at the far end of the extrusion to get the measurement of the final diameter. All of a sudden Onshape won't let me select the circle, only the circular face, and it gives me the area. Did I change a setting, or did measure change the way it works.
I just tried this in
https://cad.onshape.com/documents/cfc5dacca474c4bc3a8526d1/w/19748275a51c5aceda8d6171/e/7cc5234cfb1cabe2d63248cf
and it seems to still work for me.
I did it by:
1. Extruding the circle with a draft
2. Committing the extrude
3. Clicking on the edge of the newly created circle (clicking the edge gives me the diameter and clicking anywhere else on the face gives me the area).
Could you share your document or describe your workflow on this? Are you trying to select the resulting edge while the extrude feature dialog is still open?
This is the document, not that it means anything now: https://cad.onshape.com/documents/586f1352510777104877cbb2/w/6ecd3a9f93c8d3d90cc3faa4/e/3939e6448aafbd71211e7a8a. Specifically the problematic part was "Pentel 120 A3 DX", Extrude 9.
I tried on my Macbook with chrome and it worked fine, but the middle mouse pan is pretty strange. If it happens again, try refreshing, then if the problem continues please log a bug with support (using the 'feedback' link under the '?' menu in the top right corner). Using the feedback will give us some information about your operating system and browser so that we can try to reproduce your issue in-house.
