Linear pattern tool
Member Posts: 4
I am trying to draw a grid of circles like a peg board. I am using the linear pattern tool and I can't figure out how to specify the number of objects in both directions.
Also how can I specify the distance grid of objects are from the edge or just center them all.
  • Member, Mentor Posts: 1,584 ✭✭✭✭✭
    edited August 2015
    You don't get the option for multiple instances in the second direction until you drag out the arrow for that direction.
    This saves keystrokes and mouse-clicks in the case where you only wanted a linear pattern in one direction.
    The key to positioning is to provide constraints -- either to the end position, or a symmetric constraint involving the extreme positions, in x and y -- once the pattern is otherwise completed
  • Member Posts: 4
    Thanks I was not seeing the second arrow because I was zoomed in too far. Now I have to figure out the constraints.
    there's a good training video dealing with some aspects of constraining - I think it's this one
    https://www.onshape.com/learn/essential-training-series#!lesson-number=2&title=part-studios
    starting at about 1m30
  • Member Posts: 5 EDU
    Me too. I just spent 10 minutes trying to figure out why I can't use two directions in linear patterns anymore. I was wondering if perhaps the feature was removed. When working on small parts, I simply never had the need to zoom out that much.
    So: Why not set the initial spacing in such a way that both arrows are visible at whatever the current zoom level is?
