is it possible to display planes for mating purposes - the part is an imported rexroth extrusion
Mike_Tracy
Posts: 1 ✭
The mate connectors are an improvement over using planes. If the desired connector is not available, you may create mate connectors in the part studio or assembly. A trick from @lougallo is to add mate connectors to the origin in assembly which then can be used in place of the standard planes. Here are couple of past discussions on the topic -
https://forum.onshape.com/discussion/comment/22813#Comment_22813
https://forum.onshape.com/discussion/4517/how-to-mate-a-spring-in-assembly
www.accuratepattern.com5
I have the same question. When we insert in an assembly we can choose parts or sketches only. I guess this will be an improvement request.0
