Can Fill Pattern be used on a curved surface?
I am teaching high school students and I want them to be able to use fill pattern on a curved surface - like you would see on a kitchen strainer/colander. Is this possible? I have used fill pattern on flat objects but have had no success on the curved surface
mahir Member, Developers Posts: 1,315 ✭✭✭✭✭
Currently, fill pattern will only work on planar faces, but you can work around this by instead using a curve pattern with a curve projected onto the surface in question. See my example below. Specifically, this example uses my modified version of the Curve Pattern FS that adds the ability to specify a reference normal surface. That way everything points where it should instead of according to the curve. The example also makes use of the Tangent Plane FS by Lou Gallo.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/5b92bac572d374d2da038f5c
7
Onshape, Inc.
