How to control a sweep end profile.
Phil_G_1987
Member Posts: 4 ✭
Is it possible at the moment to create a sweep that has a different end profile to the one it starts with?
To put some context in this I'm currently playing around and modelling a weldment frame piece with a 45 degree support between an L shaped piece. I can sweep from a side profile upto a point but at that point it simply intersects with the model. As this is a single piece I can't simply trim the geometry to the correct length and angle.
I've added pictures for reference
Sweep to surface shows the geometry, and geometry used shows the sketches I created to try this out.
If anyone has any tips/ideas to share about the best way of creating this in OnShape I'd love to hear them.
Thanks!
Phil
Thanks!
Phil
caradon
OS Professional, Mentor Posts: 300 PRO
You could try a 'replace face'. Select the end of the swept tube and then the bottom of the top frame tube.
Dries5 -
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
Currently no. What I do in this situation is to use a replace face to change the termination face at the end.Phil_G_1987 said:Is it possible at the moment to create a sweep that has a different end profile to the one it starts with?
First, make your sweep
Then do a replace face on the end. Choose the terminating face of the sweep as the face to replace. Choose the terminating surface as the surface to replace with (may need to flip the alignment of the surfaces).
So for yours I would use the end face of the red part as the face to replace and the bottom of the grey part (I assume) as the surface to replace with.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
Dries
Dries
Thanks again!
