how to make a square funnel
i'm trying to make a square funnel 24in x 24in at the top and 3in x3in at the bottom. it should be 24in tall. i'm completely LOST. thank you for your help
shashank_aarya Member Posts: 265 ✭✭✭
hi @donald_8 The funnel can be created by loft method as given below.
See the document here
https://cad.onshape.com/documents/710f1bb5a3a7bac55adb0de4/w/473d0a0ca4e043a44f0da939/e/749cab5ceb66c023a7fde16f
I created solid loft having two rectangles as cross sections and then finally applied shell to give thickness. Cross sections are separated from each other by the offset plane at a distance 24 inch as per the requirement.5 -
Pahl Member Posts: 42 ✭✭
Hi @donald_8
Here is a quick video showing the steps I took to create your funnel.
Maybe you will find it helpful.https://www.youtube.com/watch?v=VuL-akYQOb8
5
