Loft issue
fma
Member Posts: 87 ✭✭
Hi!
I'm trying to use the 'loft' tool, but I'm unable to do what I want. Here is a simple case:
https://cad.onshape.com/documents/745756e8a13804d0078eb51c/w/27a362bdfeeae4d6bc3de5a1/e/0fea75d1e3af1eea2a2a2d56
How can I make the vertices from one sketch match the correct ones in the other sketch, as I don't have the same number? I don't understand how does the 'Match vertices' tool work...
Thanks for your help.
As a work around i have divided both sketch into two and lofted separately as below,
BTW, adding the central line on 'sketch to' solves the problem without the need to use multiple lofts.
Thanks!
There's something else that took me a while to pick up on, which matters for guidelines in lofts: Pierce works better than Coincident for attaching guidelines to profiles.
