College Curriculum help
steve_penicksteve_penick Member Posts: 3 EDU
My students are having trouble with the College Curriculum Lesson 3 exercise 2d, screw driver, any help available?
  • noanoa Onshape Employees, Developers Posts: 141
    Hi @steve_penick, do you know what about it is causing trouble?
    For those reading along, the exercise is described here and the public document used as a starting point is available here.
    Noa Flaherty / Customer Success / Onshape Inc.
  • PahlPahl Member Posts: 42 ✭✭
    Hi @noa thanks for the links. Looks like fun! I see it's titled Week 3. Do you have links to week 1 & 2? Are there other weeks too? Thanks
    Hi @Pahl, there's actually a full 12 weeks available! You can find it here: https://www.onshape.com/edu/college-curriculum
    @noa
    I see your one of the coauthors, nice!
    Very much appreciated, thanks!
  • steve_penicksteve_penick Member Posts: 3 EDU
    Specifically the method used to sweep remove the driver tip. Also, where can I find the answers for all the homework assignments?
    @steve_penick, the answers are actually in the same Onshape document and can be found as tabs along the bottom. This one in particular is here. If you continue to have trouble after seeing the answer, I'm sure our friendly community here can jump in and help.
    edited February 2017
    @noa
    Was going to send you a PM but could not figure out how to so guess I'll just post it here.
    First off I'm really enjoying going through your college curriculum lessons and doing the homework. It must have been a lot of work to put such curriculum together, thanks!
    I noticed at the top of the page for Week 2 Homework there is a link, "Drawings for Homework". The link goes to your google drive. The PDF drawings are all correct on the google drive, but the file names say for example "Week 5 - Part 1" instead of "Week 2 - Exercise 1".
    Thanks
  • sean_rastsmith154sean_rastsmith154 Member Posts: 4 EDU
    Sorry, I know this is an older thread, but I have some students wanting to do a screwdriver and came across this part of the college curriculum. However, when I try and access the excercise or the document, it either sends me to log-in or says not available in Google Drive. I do have an edu Onshape account. Where should I go?
    I archived the old Onshape College Curriculum plus some of my own assignments on GitHub. Here is the link. https://github.com/profbrady/Teaching_Onshape
    Brian
    Does anyone have the OnShape workspaces stored as well? I found some of them online in public, but not sure they are correct.
    Does anyone have the OnShape workspaces stored as well? I found some of them online in public, but not sure.
    Ps. Nevermind, it is loaded in the very bottom of the OnShape Curriculum folder. PDF with links to OnShape Designs.
