Creating a gentle funnel out of a surface?
nick_brooks
Member Posts: 1 ✭
I'm a beginner trying to create essentially a simple box with a spout in it to drain liquid. I've got this far (pic) with sketches, extrudes and transforms, but I'm hitting a brick wall trying to find a way to make the "inside bottom" surface curve smoothly down toward the spout.
I guess what i'm looking for is a way to distort a surface down in a "funnel" sort of way (i.e. highest at the four corners and lowest at a point that I define). Is there a simple way (or any way) to do that?
mahir
Member, Developers Posts: 1,319 ✭✭✭✭✭
Lots of ways to do this. Here's my take. It uses a two-stage loft between 3 profiles.Lofting Sketch1-to-Sketch2 hollows out the "box". Lofting Sketch3-to-Sketch4 makes the spout.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/ea9d733c17dbd650b65c9236
5
Linked[in]
When you make you funnel you can use guides in your loft to really shape how you want it to flow.
https://cad.onshape.com/documents/61cdaced1aada6c2cfc602ef/v/1eb6a49b34d244abaf12ad9b/e/359c0cd185cbed1faf230a0f
I've never played around with loft end conditions....Gonna have to look into that a bit more.
