Fully Constraint bug
rune_thorsen
Member Posts: 7 ✭
I have this simple sketch
As its black it's fully constraint, i.e. zero degrees of freedom. yes?. No
I add a perpendicular angle (take away 1 DOF)
here and it becomes as I want it. The paradox is that if it was fully constraint before then it should become red for overdefined. Or it should not have been black before as fully constrained.
john_f_carr
Onshape Employees Posts: 74
You can add a new constraint to an all-black sketch if it is consistent with the existing constraints.7 -
bruce_williams
Member, Developers Posts: 842 EDU
OK. that seems intuitive yet I did not realize it. Good info!!john_f_carr said:You can add a new constraint to an all-black sketch if it is consistent with the existing constraints.
What still seems strange - why is sketch showing defined (all black)? Maybe a constraint hiding under another one?www.accuratepattern.com5
