Sheet metal DXF export
jacob_luetkemeyerjacob_luetkemeyer Member Posts: 8
I don't know how to export a dxf of a sheet metal flat. I can get the drawing but I'm not sure how to actually export the dxf.
    edited February 2017
    You should be able to delete any sheet template entities, set the view to 1:1 then export by RMB on the bottom tab. See the settings in this picture.
