array of queries back to a single query?
johnsoggjohnsogg Member, Developers Posts: 14
I have an array of queries using this:
var edges is array = evaluateQuery(context, edgesQuery);
The `edges` array is then post-processed a bit, which leaves me with an array-of-arrays. I need to use each nested array as input to `constructPath`, but this requires a single query for its input, rather than an array of queries.
Is there a way I can create a new single query out of my array of queries?
Also, unrelated but a question I am dying to find out: is there a way to print the type of an object?
  • johnsoggjohnsogg Member, Developers Posts: 14
    Answering my own question. `var edges = qUnion(lotsOfIndividualQueriesArray)` does the trick.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,253 image
    Correct regarding qUnion.  You can get the object type by printing it out bypassing the toString methods.  The output of println("" ~ object) will have that information (try it for a few things whose type you know).
